Resolume Avenue Compositions Generator
rabosavj
Post by rabosavj »
Hy every one i developed a small app to create automaticaly composition files for resolume avenue from a folder of video clips
--| Composition Creator ChangeLog |--------------------------------------------
Composition Creator for Resolume Avenue
1.0.0.0 - 18/05/2009
First Version.
1.0.0.1 - 18/05/2009
Multilingual support.
1.0.0.2 - 20/05/2009
Autosize clips to composition size.
Removed official Resolume logo as was asked by resolume creators.
Installation:
requires .net framework 3.5 sp1 (if you don't have it the instalation program download's from microsoft site)
At the end of installation ask to install something in c:\windows\system it's the dll to extract information from avi, mov files.
It's easy to use:
1-Select a folder where you have your avi or mov files
2-Write the composition name.
3-Write a small description
4-Choose the size comp
5-Insert the desk's name, columns and layers (if are <10 write 01, 02, 03...)
If the selected folder contains more than columns*layers the program automaticaly will generate desks with the name + 1,2,3,4,5,6... and will leave one open and the rest closed.
If you want the sources ask me and i'll send it.
Hope you like it and sorry for my inglish.
If you want exists in the instalation folder a file called compositioncreator.exe.config is a xml file with the config of the application and if you want in your language translate all whats under
<setting name="sInitialTitle" serializeAs="String">
<value>Compostion Creator</value>
</setting>
CompositionCreator1.0.0.2.rar
(1.11 MiB) Downloaded 1833 times
GeeEs
Re: Resolume Avenue Compositions Generator
Post by GeeEs »
Thanks a lot for this nice little application!
Tried it for some decks and it works great! The scaling to compositionsize is a great feature!
Good job!
VJzoo
Post by VJzoo »
brilliant work, will definitely put it to good use, been wanting a tool like this for some time but I cant code. thanks heaps :D
I have a feature request if its not to hard, is to have it be able to scan sub folders and use the names of the sub folder as deck names.
keep up the great work!
Jas
(the dyslexic VJzoo)
http://vjzoo.com
~ quite nice visuals ~
rabosavj
Post by rabosavj »
ok, its easy....
Today I go on hollydays, but i'll implent it when I come back in 10 days.
VJzoo
Post by VJzoo »
awesome, cant wait :D
thanks so much for adding the feature!
have a great holiday.
Jas
http://vjzoo.com
SystemD
Post by SystemD »
Very good job !!
+1 :)
Godzil
Post by Godzil »
App not working with .swf files? :?
