When I do dual-screen mode in XP from my Macbook Pro I get a blue tinted image on my projector. Its as if one of the color channels is missing. It was working fine before with full color - but something seems to have happened.
When I boot into OSX the dual screen color is perfect.
Anyone have the same experience or ideas about whats happening and how to fix it?
						color problem - VGA out using XP on Macbook Pro
				quicksnail
Re: color problem - VGA out using XP on Macbook Pro
maybe it was just the cable? if a pin is bent or missing, or the cable is not plugged in correctly you get something like this!
				quicksnail
No its definitely not the cable - since I can boot into OSX and its fine everytime. When I boot back into XP it is blue.
