Repeatable crash on exit
gpvillamil
Post by gpvillamil »
When I quit Resolume 3, I get the confirmation dialog, and then it hangs. I have to stop it using the Task Manager.
Windows Vista SP1, Lenovo W500.
Let me know where I can send the log file!
vjloco
Re: Repeatable crash on exit
Post by vjloco »
The same thing happens to me almost every time.
Vista x64.
Laptop: Intel Core 2cpu T7200 @2Ghz - 2Gig Ram
Operating system: Windows Vista Ultimate Sp1 X64
Video card: NVIDIA Gforce Go 7600
edwin
Post by edwin »
Could it be that you guys have 'OSC' enabled in the preferences. We have troubles shutting down the OSC module properly.
mzo
Post by mzo »
Does a similar thing for me in mac os x (unexpectedly quits on exit) and it is only when OSC is enabled.
vjloco
Post by vjloco »
I checked my preferences and OSC is not enabled.
doublethink
Post by doublethink »
I have not notices a crash on exit, but on my MBP it takes ages for Resolume to exit once you tell it to quit.
HerrNieDa
Post by HerrNieDa »
i noticed if you clear all layers (playing videos) then it seems to exit smoother :D
i think there is a problem in the exit process... maybe there shoult be another tasks-order :roll:
