problem with recorded mix
Irvina_
Post by Irvina_ »
Hi
I have resolume 1.5 Trial Version and
because I want try I record mix with the specified function in resolume BUT:
No programs such like wmedia player, quick time, ...can play the file (unappropriate format) and that's incredible but resolume himself can't play the recorded file or import it !
Please help me because I wan't to be sure that the record function work easyly before buying Resolume !!
Thankxxxxxxxxxxxxxxx
irvina_
Post by irvina_ »
pleasssssse !!!
I'm gonna be crazy I can't understand
I have resolume 1;5 demo installed on another computer with XP and on this computer (too slow for mix) RESOLUME RECORD MIX PERFECTLY but ON THE OTHER COMPUTER WITH XP TOO THE AVI RECORDED FILES ARE UNPLAYABLE (by resolume too)
komart_
Post by komart_ »
did you check about the codec issue ? think Resolume records uncompressedfor me it worx,may be you should convert your recorded file first beforeto play ten with Resolume,but i can assure you that the record functiun works ( and well )
can you send us one of your recorded avi files? so we can have a look at it ...
irvina_
Post by irvina_ »
when i want to check the properties of the files it's impossible because the file isn't recognized as an uncompressed video file...win xp and resolume can't play or import the file and the attributes couldn't be determinated !
It's strange because the same os and the same demo of resolume are installed on two computer on on e it's works well on the other doesn't work...
I have dowloaded all the codecs of the hearth !
Is it a bug with xp or need I an (other) codec ? does the microsoft codecs well installed ? I can't understand but this is not my first matter with PC !
t3RRORbit_
Post by t3RRORbit_ »
i have also some problems loading a movie amde by recording function but found out why
it is this 2 gbyte limit of avi recording even if you are using ntfs which has maximum 4 gbyte maximum
so consider how big it is going to be when using 400x300x16bit i think you can record about 15 min
try to record a short clip about 5 min and check how big it is going to be and calculate how long a clip could be
recording also only works when activated dual screen i think
i would be very pleased if resolume 1.6 would support recording more then 2gbyte maybe with some kind of codec. cause i want to make video cds for saling them.
another problem i noticed is when i recorded 15 min in real there where only 12 min recorded in avi
i think this is a problem when using some clips rendered with only 15 frames per second
this should also be fixed cause i'm dj too and make music for my video cds i first record the musik then play the mp3 and make the movie with resolume so the movie is going to fit to music so i can lay the mp3 uunder the movie clips, but when recording 15 min and getting 12 min the music dont fit, SHIT
so i have to go back to make first the movie then find some vinyls fitting to them, dont like that way!!
or go to a friend and record the movie with his computer
could you please solve this problems or is this record function just some kind of effect??
