Suggestion for Live/Resolume Link
zeropoint
Post by zeropoint »
Guys.....sometime in the future it would be so cool to be able to link the loop and scrub behaviours from Live to Resolume. I know that the idea is that you can do this within Resolume but to be honest it's a fair way from being able to mix a whole AV or DVJ set seamlessly within Res alone. Resolume's strength is it's visual manipulation and mixing capability. Ableton's is it's audio. So why not play to them?
Take on the fly looping and scrubbing for example. I know you could cut up small audio loop clips in Live and have them trigger corresponding midi trigger clips going out to Resolume. But that means pre-planning. It would be so much cooler if when you selected a loop on the fly within a playing track via midi in Live that you could map the same midi control to trigger preset and syncronised loop cues in Resolume......and then as you scrub that loop in Live with the loop brace the corresponding loop in the active layer scrubs in Resolume.
You guys have most likely already considered this......just a thought.
Macbook Pro 17" 2.93ghz, 4G Ram, OSX 10.5.7, Live 8.2.2, Avenue 3.3.1, Faderfoxes LV2,DJ2, LD2, Monome 40h.
