record resolutions etc.
chris_
Post by chris_ »
Hey Bart+Eddie,
Got a coupla quick questions,
1) is it possible to record the output mix at a resolution, other than 320*240? higher would be nice.
2) if i remember right resolume kinda converts everything to 320*240 then scales it to whatever you want, is this right? Any chance of having a resoltion option in the future?
amazing work, 1.5's a killer.
cheers
chris/ snapdragon
edwin
Post by edwin »
hi chris,
if you record the output when resolume is running in 640x480 mode is records in 640x480 as well. If you this however resolume will be dramatically slow because recording on that resolution takes up a whole lot of tyour computer's resources.
edwin
Don Bloomfield_
Post by Don Bloomfield_ »
I got some good results recording at 640x480 last week, with 2 live dv feeds. Worked nicely on some at 15 frames/ sec, and not so nice other times. Make sure the hdd can cope, as it appears to just miss frames and screw with the timecoding. I'm planning on using the 15 frames/sec footage together with recorded straight footage to make a post-event dvd. Having some work was cool for this.
Have fun,
Don
Have a great day
