[New Feature]OSC output from Resolume
gpvillamil
Post by gpvillamil »
I'm making good progress on a couple of Max patches that integrate with Resolume (chaos mode, beat detect), and am really enjoying using OSC for this.
However, it would make life really much easier if Resolume supported OSC out!
In particular:
- Enable sending of BPM out from Resolume - this way I can change BPM either in Resolume or the Max patch, and they stay in sync. Right now, I have to send from Max patch only. Ideally, Resolume would echo back the same /playbackcontroller/bpm/ f message whenever BPM changes.
- Enable sending of info about layer and clip activation - this makes it possible for the Max patch to control active layer or clip, instead of deciding ahead of time to control a specific layer. This could be done by sending out the usual /layer/clip/connect message.
- Enable sending of info about the number of clips in a layer - this is useful for setting up a sequencing style app that goes through all the clips in a layer. Probably something like a /layer/numclips i message, whenever queried or whenever new clips are added or removed to a layer.
- Enable sending of info about current in/out/playhead position - this would allow things like triggering events when a clip has finished playing, moving in + out points without moving playhead, etc.
gradek
Re: [New Feature]OSC output from Resolume
Post by gradek »
+1 for OSC output, midi output would be good too.
gavspav
Post by gavspav »
Not the perfect solution as it costs money but placing a vst instance of Plogue Bidule inside Resolume should enable osc output.
Maybe there is a free solution - sonic birth?
MIDI & OSC output are definitely on our list but only for the next major update. We have a lot of other stuff to do first ;-)
serik
Post by serik »
+1 OSC Output
I would in general like it but especially to incorporate my Novation Launchpad better. Let them blink! :D
mfo
Post by mfo »
bart, when to expect that major update? Within the next weeks, months or maybe later on in the year?
(Just need to know, how much sense it makes to wait for native OSC out. Alternatively I would try a surely less reliable VST based work-around.)
mfo
Post by mfo »
Ah, a VST based solution is impossible for trigger infos. As the plugIns don't get clip triggering (by clicking) infos. (As far as I know.)
+++1 for OSC OUT!!!
freatureprogress? :-)
OSC and Midi out are coming in Res 4.
wonderfull! *huggs
