I installed the mjpg codec on a xp- machine.
Windows media player shows the video correct, but resolume does not.
on another pc (win2k) it does.
Anybody can help me to use the material on the xp pc?
thx
mjpg codec on xp
lotech_
which mjpeg codec did you install? there are about 5 available. from personal experience the Pegasus Imaging mjpeg is the nicest (http://www.jpg.com) but requires registration - the web site boasts "The fastest Motion JPEG compressor available"
