SUGG. Active clip(s) on previous deck plays as new deck load
Current behaviour is that the currently playing clip(s) gets replaced by their slot number in the new deck. (ok so at the moment there's a delay with the new deck loading
....) To me it would make more sense and enable a more fluid mix if the currently playing clip (s) continued playing in their respective layers while the new deck loads and are then replaced on triggering by the new decks clips.
Macbook Pro 17" 2.93ghz, 4G Ram, OSX 10.5.7, Live 8.2.2, Avenue 3.3.1, Faderfoxes LV2,DJ2, LD2, Monome 40h.
Re: SUGG. Active clip(s) on previous deck plays as new deck load
Forget this....I had a looping clip in Ableton that was attemting to trigger the clip from the loading deck. I have taken my trigger clips in Ableton off loop now....all fine.
