hello,
when using live feed the stream is upside down. Is there a way to correct it?
btw I know I can turn it with the use off an effect but than i can't use another....
live feed in 1.5
the fact that the video is upside down is a freeframe thing. The freeframe system works with different kind systems like resolume and vjamm and others. All those tools have a different way of working with video, that means that in some cases (like with directx) the frames are read upside down and not vice versa. We included an property in the freeframe system that sepcifies wether a frame that comes from a freeframe plugin is upside down or not. I will have a look into this try to fix it for the next release, this release will come soon because we fiexd some bugs in the 1.5 version. till then you have no choice then to use an effect to flip the video back in upright position.
