ati problems
olim_
Post by olim_ »
Helo resolumers
In my new laptop I have a ATI radeon 9600 graphic card, and I have a little big problem. :-(
When I active the dual monitor, I have some horizontal black bars flickering and interference in the bottom of my output image on tv monitor. This is stranger because when I use live camera this flickering don’t happen.
I tried everything and can’t solution this problem.
Anyone can help me? Can tell me others solutions, Please!
Olim
Emil_
Post by Emil_ »
Hy
Same problems at me !!!!
Please help
Emil
kyle_
Post by kyle_ »
have you dled the latest cat drivers... if you cant load them try the mobility modder on driverheaven.net
also under the advanced dsetting of my tv output with my ati m9... there is a flicker bar option...
Emil_
Post by Emil_ »
Hy
I have latest drivers and balck horizontal bars are still there:(
Resolume programers please help
Tnx
Emil
olim_
Post by olim_ »
I still in the same situation. Same problems with me!!! :-(
Anyone can help?
please resolumers!!
olim.
emil_
Post by emil_ »
janosch_
Post by janosch_ »
On my Laptop...
i had a gericom masterpiece and the radeon mob 9000. I made bad experience with the standard drivers, so i checked out others.
ATI let their driver sources open!!!
Thats why there are a lot of driver possibilities (for ex. http://www.omegacorner.com )
After the installation it was possible to set the card to 640x480x32 on the TV-Out (before 800x600 was the min).
After this changing the working with resolume appears more "liquid".
Also try out changes in the Graphic Settings like max performance low qual. describing them all would be to much...
Ideo_
Post by Ideo_ »
i had a similar problem and it was the ground connection of the plug..do u have the problem even if u unplug the laptop??
emil_
Post by emil_ »
same problems without ground conection on ac adapter:(
I think it's resolume problem. Owerlay works fine in other programs.
Hey guys...maybe we must buy them Ati radeon 9600 graphic card:)
Emil
olim_
Post by olim_ »
I tried everything and always the same problem!
olim
