flash clips
Lore_
Post by Lore_ »
I used to use resolume with flash clips without problems but now that I've reinstalled the OS i have some troubles: when i load the clips on the deck I don't have the preview..even in the explorer windows i don't have the icon preview of the clips..i guess i've to install some plugin but i've tried with shokwave player and flash player and i didn't solve..anyway everything seems to work in the output but's hard to understand wich clip i'm going to play..help very please!!
try deleting all the jpg pictures in the preview directory. you will find these files in: C:Program FilesResolume-1-51previews
Lore_
Post by Lore_ »
it works, tnx a lot!!
lotech_
Post by lotech_ »
I had the same problem -
Maybe a button in the preferences for 'clear thumb nail cache' in the next version?
no we want to keep the interface (including the preferences) as clean as possible ... it will only happen to maybe 0.01% of our users.
midnight.visions_
Post by midnight.visions_ »
you can write yourself a little batch file:
"del c:ProgrammeResolume-1-51previews*.jpg"
(you have to replace the path with your own...)
if you want, u can start Resolume from within this file and replace the original Resolume-Link with this file, so that the folder is cleared, every time before u start resolume...
videoteque_
Post by videoteque_ »
Nice tip midnight!
rich_
Post by rich_ »
Anyone know of a way to get thumbnials of .swf files in windows explorer with a XP OS, would be a god send?
Cheers
Lò_
Post by Lò_ »
did u install macromedia shokwave player and flash player?? if not do it..
Ideo
jintu_
Post by jintu_ »
I LIKE
