I just noticed while doing some tests, that if you have a lot of layers set up, it pushes down the comp/layer/clip panels quite far, so you can no longer access most of the parameters. While the resize handle appears between the two areas, it seems to do nothing. Up until about 8 layers things worked as expected, but by 14 layers it definitely did not work.
It would be very helpful if you could push the dividing line back up, so you an always see most of the parameters.
Also useful would be a way to toggle the display of the comp/layer/clip panels entirely, so you could have the screen filled only with the clip grid, and maybe the dashboards. That would be cool.
[request] resize clip grid vs parameter area
- gpvillamil
Re: [request] resize clip grid vs parameter area
On a standard notebook 1440x900 or 1280x800 it's almost impossible to find effect parameters in a reasonable amount of time...
pls. make dynamic sizes of the panels, or even better different views...
May be you'd be better to use dockable panels like this we will be able to have them where we and move them over the screen.
