Is there a way to use wireless cams as a source in Avenue?
thanks for any responses
can wireless/IP cams work with Avenue?
Re: can wireless/IP cams work with Avenue?
As long as the camera shows up as a proper capture device on your system you should be able to use it in Resolume. Show us the specs of the camera you have in mind and probably we can spot wether it will work or not.
