grab AVS (winamp visuals) to AVI
Slof_
Post by Slof_ »
Hi, i just found a plugin for winamp called AVSGrabber. With this plugin you can grab visuals from WinAmp to .AVI. A fun way to expand your vj-library. You can download the plugin at: http://www.deviantart.com/
t3RRORbit_
Post by t3RRORbit_ »
thanx allot
i also found a avi writer but that one was real shit nearly 70% of my avs became black avis without any grafix
t3RRORbit_
side is down!!
any other link or the filename so i can search via ftp-search for it
slof_
Post by slof_ »
Some AVS graphics cannot be grabbed with this grabber but there is another way. You can try Camtasia studio too. With this program you can select a regio of the screen and write it to avi too. Make sure you grab to a uncompressed avi otherwise the performance of your computer will be not strong enough to show a avs and compress at the same time. Camtasia studio can be found with google. The site of devianart is up again.
Ruud_
Post by Ruud_ »
cool ;) i was damned jaleous about the fckn winamp visuals too. Now 'can just rippin grab them ;) thankx
edwin
Post by edwin »
hi again,
did anyone use the Patchbox tool yet. i don't have
http://www.patchbox.net
time to figure out how it works. But it seems it's supports AVS plugins.
viscodat_
Post by viscodat_ »
hello.....i un zip the avs grabber thing....around 10 .ape files are now onboard,but what the hell do i do now'lol.......the graber.ave file won't load...uh?
please help
ALFfx
Post by ALFfx »
Damn now everybody have discovered my AVSgrabbing tool :)
Thought i was the only one using it
but lookout there are two different ones.
You really need the latest and always give a name to the file and uncompressed
You can make nice clips that way edit them later.
VJzoo
Post by VJzoo »
ive been using patch box and its realy cool i like it a lot.
ive got it feeding into resolume as a filter very cool :)
ALFfx
Post by ALFfx »
is that software?
