HiRes Playback
Cat_
Post by Cat_ »
Just thought I'd post my findings on hires performance. I'm using a Athlon 1600 in a shuttle system, Geforce4MX 720x576 32bit scaled to 720x576 then maximised.
I use 720x576 clips with picvideo Mjpeg.
In general I get 2 layer playing with little if any slowdown 3 with some slowdown. What I did notice was when fading a clip in or putting fx's on there is a slight pause before it kicks in, i've found a solution, which is to drop an effect on the clip (i use darken with 0 effect) This seems to result in no pause when triggering clips/effects. Presumably the pause is down to the effect/mixing process going throught a buffer. I know most people will go for more FX than hires output but Im a sucker for good looking video, if I want FX and Lores I use Tranzendant, subtler stuff Resolume. Thats my tuppence anywayz...
it,s great that you can actualy work at this resolution ... do you experience the small lag with freeframe plugins? or also with the built in effects?
cat_
Post by cat_ »
Built in as well. I had a gig Saturday and also found my work-around slowed things down a bit more than I realised while testing! So now i found out about the Ctl+effect key for loading in to specific clips I use that before I use an effect that needs to snap in on time!
Good to meet you guys at avit too!
ta ta
Xavier Plágaro_
Post by Xavier Plágaro_ »
You can make Resolume work at 720x576?????????
How??????????????????????? ;-)
