Resolume and blackmagic decklink card
kiabehin
Post by kiabehin »
hello everyone
i'd like to know if someone use resolume with a blackmagic deckllink card as video output with SDI out for resolume? could we use that kind of card with SDI Output working in resolume?
any ideas?
thanks
maylae
Re: Resolume and blackmagic decklink card
Post by maylae »
Hi, a need too an HD/SDI output 1920/1080 whith resolume and decklink studio...
THANKS
The Blackmagic cards can not be used as a video out. Resolume requires the videocard to render all the video the Blackmagic cards can not replace a videocard. It is technically possible to read the pixels back from the videocard and push them out through the Blackmagic output but it's very slow ;-( Especially at HD resolutions.
If your budget allows then you could get a videocard from PNY that has SDI out, but it's expensive, think 4 to 5000 USD ;-)
http://www3.pny.com/NVIDIA-Quadro-FX-58 ... 3C366.aspx
jonek
Post by jonek »
why don't use one of mini converters from BlackMagicDesign?
hdmi to sdi
http://www.blackmagic-design.com/produc ... onverters/
for about 500$
it is external, so you can use it with laptop,
however, I am not sure about picture delay if your beamer will be "far away" :)
