divx
Lò_
Post by Lò_ »
sorry for my dub question, but resolume can't play divx right? which is the best to do then, recompress vith virtualdub and other codec? which one do u suggest?
t3RRORbit_
Post by t3RRORbit_ »
indeo 5.11
with 15 fps
and keyframe every 1 frame
relosution 320X200 or 352X288
15 fps is a bit low you can use 25 fps ...
Lò_
Post by Lò_ »
i use virtual dub and i've got indeo 5.10 is the same or the 5.11 is better? where do i find it?
thanx
ideo
