RECORD FEATURE WANTED
t3RRORbit_
Post by t3RRORbit_ »
i just tested the new version 1.51 with its recording function, there is still the error with recordings bigger then 2 gb, but i had an idea how to "fix" this problem!
is it possible to stop the recording and generate a new file automaticly when reaching the file limit, instead of letting the user do this, i just want to be able to make a whole recording of a gig, maybe 2 hours, disc space is no problem i think and encoding to an other codec and putting all parts together is no problem too.
this would be so cool, please implement a make a new release!! PLEASE!!
howly shit we never even tried to find out what the maximum filesize is ;-)
we,ll look into this ...
t3RRORbit_
i dont which codec is used or if a codec is used, but if original avi is used, the maximum file size is 2gb
the recording function generates movies with up to 4 gb then the maximum filesize of fat32 and ntfs reaches and it stops, but no program will be able to open files bigger than 2 gb
thats the reason why i have to stop the recording every 12 minutes or so, and begin a new one to get recordings that i am able to use
