MIDI buttons
kel_
Post by kel_ »
I have problems in R1.5 with midi. I cant assign the buttons.Resolume registrate it, but nothing display in the configuration frame. Du u know where is the problem? in midi. in comp (W2000), in integrate soundcard (no another problems with fadrs,potenciometers...)pls HELP:)
sensualvibes.6x.to_
Post by sensualvibes.6x.to_ »
possible that the buttons send no velocty?
syzygy_
Post by syzygy_ »
I recommend downloading midiox and checking what midi data your device is sending to resolume.
When you say that resolume 'registrates' the input, do you mean that the midi key is shown in the box in the midi configuration when you press it?
Dan.
