Yo, guys..
I mapped my keyboard controllers to resolume:
preferences->midi mapping->controllers
seems that at the end of the controllers list there's a small error:
Instead of:
opacity effect: layer 1
opacity effect: layer 2
opacity effect: layer 3
I had to map the midi controllers to:
opacity effect: active layer
I guess the controllers list is shifted by one at a point.
Is there really a bug. I use a Toshiba p3 1.8Ghz with a Korg Karma for my jams.
And a question..
is it possible to save other settings in the decks? For example the chaos configuration, the initial layer opacity (levels always at 100-50-50 when starting resolume) and perhaps the transition mode (bmp file)? That would save a lot of time when shifting the decks during gigs. Is there any chance to implement a pref file to remember all these settings?
I know I'm a little picky but ...Anyway - Resolume KICKS ASS! You guys are great!!! Keep the good stuff!
Thanx
VJ Thomas
