GeForce4 4200
François_
Post by François_ »
I just bought a new dell computer with a 15.4 sceen (kind of widescreen view with a resolution of 1680x1054) with a geforce4 4200 onboard.
When I resize the dual screen to 1024x768 and 800x600 for the s-video out... it's look good, when the I don't resize to a fullscreen view. When I try to put it a full screen... the output look posterize and pixelate.
Any clue? Does Resolume support geforce4 4200?
François_
Post by François_ »
Actually it's a 64MB DDR NVIDIA GeForce 4 4200 Go AGP 4X Graphics...
how do you set the output to fullscreen on the second screen? try maximizing it ... please see out manual to find out how to do this ...
François_
Post by François_ »
I do the ctrl+alt+2 (at this point what I see is perfectly clear on the tv out... and after that, I do ctrl+alt+enter... at this point it goes solarize+pixale... if I stress the coner of the output... it goes well till I get near the fullscreen...
François_
Post by François_ »
shit... if I strech the corner of the output... sorry for that bad writing...
François_
Post by François_ »
Hi...
I try many way to configure that video card... and the problem comes from the widescreen.
So I figure it out by trial and error until I found the best solution. It consist of configurating the output at 640x480 and by a right click on the right of the caption bar and the output window I managed to find the best resolution... If I do the ctrl+alt+enter... it strech to fit on the widescreen 15.4". I will give a try to the ctrl+alt+m this afternoon.
thanks... for your time...
Best regards,
