BUG: Opening Deck from other comp. replaces Deck 1
craftycurate
I have a composition with 3 decks, and I want to add in a deck from another saved composition. When I do this, the deck I add replaces the first deck in my composition instead of adding it.
Re: BUG: Opening Deck from other comp. replaces Deck 1
If you try to import a deck which is a copy of the one in the composition, it will replace the original deck. I believe this is a bug. If you try to import a deck which is not a copy, it should be added to the existing decks.
The way I deal with this is to only have one version of each deck, leaving it in the original composition, and then dragging it to the composition I want when I need it.
Laptop: Intel Core 2cpu T7200 @2Ghz - 2Gig Ram
Operating system: Windows Vista Ultimate Sp1 X64
Video card: NVIDIA Gforce Go 7600
craftycurate
Yep that's exactly what happened - it was a copy of another deck.
