Changing Location of a Composition's clips
zeropoint
Post by zeropoint »
Is there any way to do this? I have been prepping my compositions with my clips running from my large studio drive and would like to now run them from my mini portable raid.
Macbook Pro 17" 2.93ghz, 4G Ram, OSX 10.5.7, Live 8.2.2, Avenue 3.3.1, Faderfoxes LV2,DJ2, LD2, Monome 40h.
gradek
Re: Changing Location of a Composition's clips
Post by gradek »
have not tested this but according to smuseus
You can relink your files by opening the composition file in a text editor and "search and replace" the new path of your video files.
http://www.resolume.com/forum/viewtopic ... 809#p21904
VJair
Post by VJair »
might be easier to just make sure your external drive has the same letter ( ie - D: ) as the drive the clips were orriginaly on. havnt tried it with Avenue, but it works with other softwares.
digital:snot
Post by digital:snot »
to change drive letter in XP
on fresh reboot with no programs running
1. as admin, Right-click "My Computer"
2. click "manage" from the popup
3. Right-click the drive, the partition, the logical drive, or the volume that you want to assign a drive letter to, and then click Change Drive Letter and Paths.
4. Click Change.
5. Click Assign the following drive letter if it is not already selected, click the drive letter that you want to use, and then click OK.
6. Click Yes when you are prompted to confirm the drive letter change.
zeropoint
Post by zeropoint »
Thanks guys.....it's a shame that Res doesn't have some sort of project handling system like Live....
zeropoint
Post by zeropoint »
Strangely, since I used the other drive, my compositions do not display correctly in Resolume's browser. There are no composition names......the number of decks is displayed but the decks themselves do not show....Bart/Edwin any ideas why this should be happening and how I can get them back?
lo-res
Post by lo-res »
gradek wrote:have not tested this but according to smuseus
I am using a macbook pro. I am a little confused, can anyone give me a clue as to what I need to search for and what I need to replace it with. Sorry for being a bit thick here.
lo-res
Post by lo-res »
ok, I've managed to do a find/replace and updated all the file paths. When I re-open the composition about half of my files are no longer in place in the composition.
I'd be interested if anyone has the same issues or knows of a solution.
Cheers
gpvillamil
Post by gpvillamil »
Try using a programming editor like NotePad++ that does refactoring, not just search and replace.
lo-res
Post by lo-res »
thanks, I'll give it a go.
