broken white edges on output
zeropoint
Post by zeropoint »
Now that I have started projecting with Resolume, I am noticing broken white edges on the output with clips with black/dark frame edges when set to full screen, usually on the top and right. This also happens with full screen on my 23" Apple Cinema Display. Any ideas?
Macbook Pro 17" 2.93ghz, 4G Ram, OSX 10.5.7, Live 8.2.2, Avenue 3.3.1, Faderfoxes LV2,DJ2, LD2, Monome 40h.
Re: broken white edges on output
Screenshot?
zeropoint
Post by zeropoint »
Hi Bart
Strangely it doesn't really register with a screen grab. It's a tiny thin line with coloured pixels here and there on the top and right side. It is there on my laptop screen, my external monitor and you really notice it when projecting.
I have mailed you a flip video clip of my monitor that shows it clearly
zeropoint
Post by zeropoint »
And by the way....it's not the graphic card as other apps go full screen on their output with no problems....
zeropoint
Post by zeropoint »
Worked through this with Bart and discovered this problem only occurs for me when Resolume is set to output at 640 x 480. All the other output resolutions work fine. Changed the resolution to 641 x 481 and all is ok.
