Hi!! I need some help-.. just bought the Novation Nocturn, to control Resolume 2.41.
I installed the disc, wrap the plugins, everything ok with that...but when I try to asignate the parameters it doesnt work.
I think that it can be a problem with the Automap Universal System.
Anyone has test it? or knows if it is compatible?
HELP! couse I really like it!!
Thanks for your time.
All best,
Simia
Novation Nocturn
Re: Novation Nocturn
Has anyone got one of these to work?
as far as im aware ( i have a zero sl ) - automap itself doesnt work with resolume or avenue - that shouldnt stop it working as a normal controller, it just means the setup is a little more manual.
- rxfromparis
works for me, Automap is just a hassle to setup
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000
