Is there a simple way to reset the in/out points in R3 like the alt-i/alt-o in 2.x or has this not been implemented yet? Also, any way to fine tune these points without using the mouse would be handy, esp on longer clips.
thanks,
Z
loop point reset
Re: loop point reset
hi Zandango,
You can map a nob or fader of any midi controller to the in and out points, that way you can tweek the i/o location in real time by turning a nob. You could also map the i/o points to a keyboard key or midi button too. That way you just hit the i point while the playhead is moving. but I fear there is no reset yet (or is there?) ... would be a good feature request.
Thanks, I'll give the knob mapping a try.. but I have a feeling that for a 20min clip it won't be very accurate. A simple reset would make things a lot easier.
I've been loading in 20 minute clips multiple times and messing with in points, sequencing with energyXT. It's an interesting combination for AV esp with Energy's new live marker triggering. It's less of a system hog than Ableton too.
