BCR200 with Vista?
BCR200 with Vista?
On BEHRINGER's site you can find drivers for windows xp only. That's it? now that i got Vista I need to sell my BCR2000?
						Re: BCR200 with Vista?
I'm using my BCR2000 without a driver, and it works fine.  Do you run Vista-32 or Vista-64?
vista 32 resolume avenue trial
Strang... I also use Vist-32 Home Premium, does the BCR-2000 show up in the device manager?
						- Tschoepler
I even use it running Resolume on Vista 64. With the build in Vista drivers.
First it seemed to not function at all. It appeared in the Resolume prefs but mapping was not available. Then after restarting the system TATA all the functionality was there.
