tek speks for speeeeed.....
ether....WarpTV_
Post by ether....WarpTV_ »
Hi again
I would like to know where in the PC most of the number crunching is done with resolume, so i can get the best possible performance.
My current PC specs are:
athlon1.2GHz
256 DDR RAM
matrox g450eTV
ata100 hard-drives
if i were to upgrade one piece of hardware, which piece would give the most significant perfomance boost?
thanks
most of the hard work is done by the videocard so you should upgrade your Matrox to a Geforce2 mx with twinview or a radeon 8500 with dualhead ...
