[bug] FFT Bandpass Pointers
quazielectrojam
Post by quazielectrojam »
There seems to be an issue with the high frequency cut-off pointer - if it gets set all the way to right on the audio spectrum analyzer, the FFT signal gain gets pegged to max and therefore stops responding to the audio signal. Btw, what are the frequency limits of the FFT filter?
Tschoepler
Re: [bug] FFT Bandpass Pointers
Post by Tschoepler »
Same here.
Could you explain a bit more what does wrong exactly? When you move the right slider of the frequency selection what happens exacty?
Tschoepler
When the right slider is at the very right (HighFreq) it stops the FFT analyses. As soon as I drag the slider just a tiny bit to the left the FFT will pick up the work immediately.
