Moving Compositions to other computers
nokra
Post by nokra »
Hello,
I wanted to move one of my compositions to another computer (both are macs) but Resolume didn't find the footage and ignored it. Seems that there is no search function or s.th. like that. As I was messing around with lot's of fx, it would take enormous effort to rebuild the entire composition.
Has anyone a solution for that?
Thanks,
Norbert
Rene
Re: Moving Compositions to other computers
Post by Rene »
take a look at http://www.resolume.com/forum/viewtopic.php?t=4646
you have to modify the path to your clips in the .avc xml file. This should work.
