Ati HD 4350
add
Ati HD 4350
Post by add »
Does anybody uses this card on Resolume Avenue? Ati HD 4350
I have an event in few days and need something urgent.
Please any feedback will be ok.
rabosavj
Re: Ati HD 4350
Post by rabosavj »
may be if you say what is the problem or what is waht you need........
add
Re: Ati HD 4350
Post by add »
Just want to know if this is a good card for resolume.
If so, i´ll buy it.
HerrNieDa
Re: Ati HD 4350
Post by HerrNieDa »
if you want to go higher resolutions than pal you shoult get at least a 4650 or something
i got a 4670 with core2duo and 2gb ram, lasts for 10 layers and effects in pal resolution ;)
720p also runs smooth with 4 layers...
