About Midi
Steve_
Post by Steve_ »
Hi there
It's possible to trigger the effects with midi, i'ts also possible to apply effects to a channel when you push CTRL "shortcut" How can I trigger an effect directly to a channel with midi. With midi it always applies the effect on the final output right?
Please help Thanx
alex_
Post by alex_ »
i have the same problem.
Also i´m not able to switch the effects on bypass.
And it would be nice to can declare controllers as rotary knobs, that change a value relative
-> the value would´nt jump, if i change f.e a layer.
possibly maybe
love alex
sensualvibes.6x.to
ticks_
Post by ticks_ »
Is there anyone who has an idee to fix this problem
thanx
Flip_
Post by Flip_ »
Hi All,
Resolume only reacts to midi signals when they are mapped to an event. So you can send what ever midi signal you want, Resolume won't trigger an effect into a channel because they are not mapped to channels.
Resolume internally knows what to do when the CNTRL key is used: the effect has to be placed in the channel, not the main output. I don't know how Eddy/Bart programmed this: if they added the CNTRL value bitwise, this results in parameter values beyond the midi scoop (0-127).
My suggestion for Bart/Eddy: make the CNTRL key assignable by a midi note, in hold mode and with an indicator in the GUI. For keyboard users: in this way you can create a CNTRL key on your keyboard which swithes layer/channel mode for effects. For controller users (like MC33), get a keyboard for this!!!
Personally I think it's better to store the channel effects in your deck, and use a controller for the alfa.
If I get any other ideas, I let you know ...
Greetz
