Resolume API with Flex Applications
silex
Post by silex »
I'm trying to include the Resolume Flash API in the SourceBinder project as an export option. The exported swf is a Flex Application, which works well in Resolume except for the published parameters. I think this problem is related to the fact, that the swf was compiled not with Flash CS4 but with mxmlc, so the request from Resolume comes sooner than the addparameter scripts are executed (You can find a small flex example with the source code at http://www.visualminds.hu/resolume_flex ... metest.zip). Do you know any solutions for this problem?
