Some dood (no, not me:) made a forum for people curious about the DM2 controller from mixman as a midi device - http://www.dmtwo.tk/
(if you dont already know, check out http://www.pdoom.ch ) you can use th DM2 as a midi device, and only spend less than $100
Anyone out there using a DM2 in their setup? Wanna talk about it?
DM2 Controller & Resolume!
syzygy_
We use a DM2 with resolume for some of our gigs.
It works really nicely, especially if youi create special decks for it (some 'left' decks with only the first 8 clips assigned, some 'right' decks with only the second 8 clips assigned). That way you can load the left while using the right and vice-versa. You also have 4 clips left over of logos etc that you don't need to change during the gig.
(we also set it up so that the left hand buttons on the DM2 load clips into channel 1, the right hand buttons load into channel 2 and the cross fader control the opacity of channel 2)
Dan.
Dan.
jeffhtg_
