Auto-Trigger and Composition Beat Snap
potoche
Post by potoche »
Hi there
I'm using Resolume 3.0 with MAC OS X on a mac book pro and it's working great!
I'm still searching for those 2 features though :
Auto trigger : Is there a way to make Resolume switch automatically from one cip to another when a clip is finished?
Composition Beat-snap : tweaking the beat snap for a CLIP is working great (let'ssay 1 bar for example). But choosing a beat snap for the whole COMPOSITION doesn' make any change. The clips are triggered immediately once i call them. Is that normal?
Thank you all !
Re: Auto-Trigger and Composition Beat Snap
potoche wrote:Auto trigger : Is there a way to make Resolume switch automatically from one cip to another when a clip is finished?
No not yet but it's on our todo.
potoche wrote:Composition Beat-snap : tweaking the beat snap for a CLIP is working great (let'ssay 1 bar for example). But choosing a beat snap for the whole COMPOSITION doesn' make any change. The clips are triggered immediately once i call them. Is that normal?
Beat-snap only applies to clips that are on BPM Sync mode, perhaps you are triggering clips in timeline mode?
