Hi all!
My situation, first.  I'm VJing in Resolume 2.4.1 until the FreezeFrame plugins work in 3.  But I'm tired of borrowing laptops for every remote gig.
What I'd really like to do is get a MacBook Pro, and whenever it's time for Resolume, I'd boot into Windows XP via Boot Camp, hook up the DVI-to-s-video adapter from my laptop to a projector, and rock out.
But I've seen a number of posts warning that the DVI-to-s-video adapter won't work in Boot Camp!
All the posts seemed to be pre-Leopard, but absence of evidence is not evidence of absence, right?
So I submit the question to y'all in forum-land: Has anyone had success running s-video out from Resolume when in Boot Camp on a MacBook Pro?  Does the DVI-to-s-video adapter do the trick, or do I need something like the Grandtec VGA to S-video Converter?
Much thanks in advance for your help!
D
						MacBook Pro + Boot Camp + Resolume 2.4 + S-video = ?
				BuckRogers
Re: MacBook Pro + Boot Camp + Resolume 2.4 + S-video = ?
It's all written about before. See this thread. S-vdeo will not work as far as I know, correct me if I'm wrong. Composit will.
Much thanks!  This is amazing---they're saying it works with just the regular DVI to s-video cable, no scan converter needed?  That's... amazing.
