hi,
i work with resolume on my vj sets at home using a pc. but when i want to open my projects on different computers (and laptops) resolume just opens my project without any of the clips.
resolume recognizes the project and its settings but cant find the material.
of course, when i transfer the project to another computer, i also transfer the all the clips. but still resolume doesn't show them...
is there a way to reconnect the clips to the project?
thanks, danny.
problem opening project on different computers
Re: problem opening project on different computers
No unfortunately this is not so easy, we have some work todo on this.
But it is possible, you need to make sure you put the materials in exactly the same directory structure on both computers. This means the full path needs to be exactly the same. For instance: C:\data\footage\clipname.mov
It is also possible to the open the .avc file with a text editor (NOT Word, but Notepad) and search and replace all the paths.
hmm... that's pretty frustrating...
too bad, i really enjoy working on resolume.
i hope you will get it fixed someday.
good luck.
good luck.
