Hi all and specifically the Resolume makers,
this is Dorian from Masterdamus live visual productions (http://www.masterdamus.com)
I've found one important tweak that has to be made...
There is a problem with the layer browser window.
especially when using low resolution monitors (15" @ 1024x768), you can only see 3 layers.
thats not a big problem, but when you add a layer to have x4 of them, the 4th top one is almost invisible.
to get there you have to scroll up.
the problem with that is that, when you do that you loose the ability to have sideway navigation, and if you wanna go left or right in your clips in that layer or any layer, you cant reach the sideway browser arrows.
only when scrolling back down to see the sideway arrows again...
small but much needed, as it feels like a bug or Un-thought-of functionality of the browser window.
all the best people, and hope to get your feedback on this.
Respect & creativity
Dorian - Vj masterdamus
Sideway navigation in layer browser window
masterdamus
Re: Sideway navigation in layer browser window
+1
and the fact, that it is not possible to change the size of the layer window IMHO is a shame! (adjusting effect parameters on smaller screens becomes rally a pain!)
Making the scrollbars separate from the grid is on the to-do list.
- gpvillamil
and make the column headings separate too. If you scroll down, the column headings go off the top and you can no longer use them to trigger entire columns of clips in one go.
