Sideway navigation in layer browser window
masterdamus
Post by masterdamus »
Hi all and specifically the Resolume makers,
this is Dorian from Masterdamus live visual productions (http://www.masterdamus.com)
I've found one important tweak that has to be made...
There is a problem with the layer browser window.
especially when using low resolution monitors (15" @ 1024x768), you can only see 3 layers.
thats not a big problem, but when you add a layer to have x4 of them, the 4th top one is almost invisible.
to get there you have to scroll up.
the problem with that is that, when you do that you loose the ability to have sideway navigation, and if you wanna go left or right in your clips in that layer or any layer, you cant reach the sideway browser arrows.
only when scrolling back down to see the sideway arrows again...
small but much needed, as it feels like a bug or Un-thought-of functionality of the browser window.
all the best people, and hope to get your feedback on this.
Respect & creativity
Dorian - Vj masterdamus
homing
Re: Sideway navigation in layer browser window
Post by homing »
Yep, a major annoyance for me also.
This will be fixed in version 3.2.
