Hi!
I'm testing avenue3 before to buy it...I have a Nanokey, and it work very fine with avenue, but can I use nanokey and nano Kontrol together? can I attach together at my laptop?
Because I would like use the nanokey for the piano-control and the slide of the nanoKontrol for control the fade in-out and other things....
thanx
s ine
NanoKey and NanoKontrol work together?
Re: NanoKey and NanoKontrol work together?
Hi Sineglutine
Resolume will recognize different midi input signals and controllers. As long as your laptop has enough USB ports and can provide enough power, it will work. If you want to be absolutely sure, just take your rig to the store and try it out. Most music stores will gladly let you try stuff out first if there's some money to be made later.
the power thing can be critical, espeshually with these devices as usb powered only, I had a case where I was running NanoKontrol, a video capture device and midi usb dongle, and signal kept dropping in either one of the midi devices, I thought it was dodgie usb ports, or conflicts, I tried so many things to work it out. I was on tour with a band at the time so hard to try and get support and help. When back home I explained the problem and friend instantly told me to check power, brought $10 powered usb, problem solved.
What about NanoKontrol and one more NanoKontrol work together? Is it possible?
as long as you have set the controllers up to send different messages (you don't want both kontrols sending CC23 over channel 1 or they would both affect the same parameter)Godzil wrote:What about NanoKontrol and one more NanoKontrol work together? Is it possible?
there is an application from Korg that allows you to program your controller messages
Asus build - intel 2.8GHz T9600, 4GB 800Mhz DDR2, ATI 4670
Rack unit - intel 2.7GHz q6600, 8GB 1066Mhz DDR2, 9800GTX+, intensity HDMI input card
But the korg app recognizes only one device when 2 controllers is connected.pleasuretek wrote:as long as you have set the controllers up to send different messages (you don't want both kontrols sending CC23 over channel 1 or they would both affect the same parameter)Godzil wrote:What about NanoKontrol and one more NanoKontrol work together? Is it possible?
How can i change that?
