nvidia-ati?
noce_
Post by noce_ »
hi all
is the NVIDIA® GeForce™ FX Go5200 64mb videocard for laptop good to run resolume? and what about ati mobility radeon 9000 64 mb? which is to prefer?
i was sur to take ati when i saw this: http://www.computercityhw.it/Computerci ... id=42&sr=0
tnx 4 advices
we usually prefer an ati radeon as they have better tv-out and Theater Mode.
noce_
Post by noce_ »
tnx...that's what i supposed was the answer.
tnx for resolume. and fast reply to questions.
pis&low
fryjk_
Post by fryjk_ »
hi all! do you people normally use s-video out on graphic cards to output to a video projector? my question is: when using dual monitors, one being the pc monitor and the other your tv/projector, you have to set the refresh rate to 50hz (PAL, i'm in europe) which in many cases means you are going to damage your computer monitor, which generally do not support refresh rates below 60hz. is there any work-around this issue? when you read about graphics cards outputting at two different resolutions it kind of makes you forget that they're outputting at the same refresh rate... do matrox dualhead cards output at different refresh rates?
any help on the subject would be very, very, very much appreciated. thanks
