resolume 3 et windows seven
schranzkiller
Post by schranzkiller »
j'arrive pas à lancer résolume 3 sous le OS windows seven il me le ferme dès son ouverture
comment puis-je faire pour le faire tourner correctement
merci
régis
Re: resolume 3 et windows seven
Hi Régis
I hope you don't mind if I reply in English. If I understand you correctly, you are trying to launch Avenue on Windows 7, and it crashes while opening.
Resolume Avenue has been tested on Windows 7, and is working fine for most users. There can be any number of causes for your problem however.
Could you please send us the logfile that Resolume creates on your computer (C:/Documents and Settings/[username]/Application Data/Resolume/Resolume Avenue 3 log.txt)? You can either post it here, or send us an email at support@resolume.com
Hopefully that will show us what is going wrong.
