Midi was working then not in Avenue
VJ Rhett Bice
Post by VJ Rhett Bice »
Midi stopped working in Avenue.
Myassignments still show up on the lables. midi tracking software shows that the signals are being received by the mac.
osx 10.5.6
Any ideas?
Re: Midi was working then not in Avenue
Hi Rhett
Could you send us the log files? Also, any ideas on something that might have changed in your setup?
VJ Rhett Bice
Sure, where do I find them?
MAC: /Users/[username]/Library/Logs/Resolume Avenue 3 log.txt
You can post it here or send it to support[at]resolume[dot]com.
Also, double check if you have turned on the midi input of the correct device in the MIDI Preferences.
VJ Rhett Bice
Great thank you. I'll get to these items tomorrow or the next day. Sorry i can't do it right away. I'm a little overwhelmed with work at the moment. : )
Biomanniax2
Post by Biomanniax2 »
sorry to hijack your thread but im experiencing the same problem with my behringer controller. what midi tracking software do you use on the mac to see if the signals are still coming in ??
did you find a solution to your problem ??
cheers, steve.
VJ Rhett Bice
I stopped suing the mac for Resolume but... I believe I was using and app called MIDIMonitor. The dmg file for that program is still sitting on the desktop anyways.
