Is there any way to more precisely set the in and out point of a clip? ie. use the cursor keys or the like to nudge it left or right by, say.. one frame at a time?
If not, would you consider adding this?
Alternately is there a way to do precise zooming on a portion of a clip waveform while setting the In/Out points? Or just the two levels of zoom that I see now?
Also, is there a way to map a MIDI slider or knob to the In or the Out point setting?
In/Out Point control.. Precision.. MIDI control...
Re: In/Out Point control.. Precision.. MIDI control...
Hey Fongaboo
At the moment we have no shortcuts assigned to the in/out points, nor can you assign midi control to it. Some other people have requested similar features, and we're looking into how to best implement this functionality.
To have more precision, you can use the CTRL key on a PC or CMD key on a Mac to scrub more precisely. When you're zoomed in, this should give you per frame control even on long clips.
Hope that helps.
Hope that helps.
