a very big composition file
sineglutine
Post by sineglutine »
Hi
I'm trying Resolume 3.0 a few days before buy. I tried to create many compositions and the
save files are always small (about 1-2Mb). Yesterday I created a
composition with many pictures and 3 videos, 2 with a Indeo5.1 codec and 1 with DivX codec
and the resolume's file came about 24Mb, making it unmanageable, and the transition from one deck to another very slow.
I work with a Matrox DualHead with output of 1280x480
Why this difference in dimension?
thank you!
Re: a very big composition file
Hi Sineglutine
The speed at which you can switch between decks is one of the major points of improvement we are working on at the moment. Be sure to always have the latest version installed to make sure Resolume is running optimally.
As to the size of the project files, can you send us a link to the file so we can have a look at it? You can also mail us at support[at]resolume[dot]com if you prefer.
