hi guys
after i installed the resolume 3 the newest version, i can't play videos with audio. even the videos that came with resolume just don't work.
any sugestion
tks
video problem
Re: video problem
did you take a look at the audio preferences?
in the new versions the audio-interface-part has fixed some problems (in vista/7 i think)... may the preferences are loaded from the older version and so it won't work out of the box...
Re: video problem
If Herrnieda's suggestions do not work, please send us the log file that Avenue creates on your computer.
MAC: /Users/[username]/Library/Logs/Resolume Avenue 3 log.txt
PC: C:/Documents and Settings/[username]/Application Data/Resolume/Resolume Avenue 3 log.txt
Re: video problem
problem solved
ths to herrnie da
the stupid vista blocked the audio.
thanks guys
ths to herrnie da
thanks guys
