downloading music or sound
simon_
If you want to use sound with your set then its a case of either.
using a seperate dj soft and keeping them seperate.
Or triggering clips via a sequencer, like ableton, or even some of the dj soft like traktor. this way you can preplan a show with certain tracks triggering clips at various points.
Thats ONLY if its just clip triggering, not synced video. For full synced AV you would have to trigger a clips and have it play in time, and at present resolume wont sync to midi clock. There are solutions for that but I wont go into all that unless someone has a specific question.
simon_
diplodocus_
Dan_
