hi guys
I applied a mask to a composition.
The problem is that some effects that apply to the composition does not comply mask...
... why?
I have last relase of resolume
thanks!
some effects not respect mask
- Tschoepler
Re: some effects not respect mask
- what format is the mask.
- which effects do not comply?
hi,
this is the mask
http://picasaweb.google.it/lh/photo/oNM ... directlink
and the effects that have problems are:
mirror-black hole
shift glitch - orizzontal
static subtle
and others like blendoscope or circle...
the effect appears wrong in the red areas of mask
thank you!
this is the mask
mirror-black hole
static subtle
thank you!
Hey sineglutine
As far as I can tell, your image is red and white. A mask should be grayscale, where black will mask out the video and white will leave the video visible. Gray will make the video slightly see through.
When changing the red to black, the mask works as expected, with all the effects you mention applied.
Hope that helps
Joris.
Hope that helps
Joris.
hi!
thank you for you help but ....I tried ... but doesn't work even with black!
I don't understand, I regret not being able to use some effects on my composition!
bye bye
bye bye
Hmmm
Maybe I'm misunderstanding what your problem is. Could you outline the steps you're taking, what you're thinking should happen, and what is actually happening?
thank you goto10,
tonight post a small video with the result of this composition
hi!
Sending a test made by applying a mask to the composition
http://www.youtube.com/watch?v=mO-kPx-UeRc
I applied the effects in this order:
- static subtle
- mirror black hole
The third effect still works: stripper
thanks!
- static subtle
- mirror black hole
thanks!
Thanks very much for the video. It shows very clearly what the results are.
Still, to fully understand the problem, the steps you take to get this result are equally important. From what I gather from your posts, you do the following:
- 1 layer playing a fullscreen clip
- apply vertical striped mask (.jpg file) on the composition properties mask
- apply effects at the composition level, all at 50% opacity set to add blending mode.
Then you are expecting that the effects are only applied to the areas which are NOT masked out, but what is actually happening is that they are applied everywhere.
Is this correct? If not, maybe a screen recording of your Resolume interface showing what you're doing is an option for you?
The reason we need this info, is to be able to fully recreate the problem on our end. The only way we can recreate it at the moment, is by applying the mask at the layer or clip level, in which case this is expected behaviour.
hi!
as you suggested I did it again all the steps to compose my set up and now ...
everything ok! I solved the problem!
I had not correctly applied the mask to the composition! now it works very well!
Thank you for your patience!
sines
sines
