I've been playing with the demo version of resolume, and I can't figure out how to apply a mask file? I've made a few .PNG files using photoshop, and I can see where to drag the file in the composition, layer, and clip menues, but it dosn't seem to work. do i need to have the .PNG file saved in a certain folder? currently they are on my desktop.
I'm on a macbook pro 2.5 using resolume avenue 3.1.3
									applying masks from a MBP
- Stickygreen
- Stickygreen
Re: applying masks from a MBP
OK just figured it out.....
I was trying to drag and drop the clips from the desktop into resolume, what I needed to be doing is to be using the finder in resolume to drag the .PNG files from the desktop to the mask spot, then it works. seems totally stupid. but thats what I was doing wrong?
yup.but thats what I was doing wrong?
We will make sure you can drag and drop masks from the finder (explorer) in the next version.
						- Stickygreen
just to let you know edwin, i wasn't using finder i was dragging the ,PNG files right from the desktop. also I tried versions 3.1.2 and 3.1.3 in case you wanted a bit more info on the issue
oh and thanks for the awesome software, really liking it.
